CCM 5.0 and VanDyke SFTP server for backups issue
May 15th, 2007
I am having trouble using VanDyke SFTP server for CCM5.0 backups. I have tried every possible combination and it does not work. The logs on the vandyke sftp do not show errors, but ccm5.0 will not accept it as a valid sftp server. I have verified connectivity as well via ping. any ideas?
thisisshanky Tue, 05/15/2007 - 12:01
  • Purple, 4500 points or more
Use a sftpd client to see if ur server configuration is proper.
I used freeftpd (which has sftpd in it). It works just fine. I use anonymous login. So the server doesnt care abt the password at all. This may be a security risk, so you may want to setup Windows NT based authentication on ftpd.
Sankar.
PS: please remember to rate posts!
