VG224 Ampphenol port: Male or female?
Answered Question
Overall Rating: 0 (3 ratings)
Correct Answer
rob.huffman Tue, 05/15/2007 - 11:32
Hi Michael,
The Amphenol port is Female so you will need to order a Male RJ21.
Hope this helps!
Tommer Catlin Tue, 05/15/2007 - 15:41
Be very careful though. Dont let your vendor buy cheap amphenol cables. I had some data cabler putting in 6 pairs for vg248s. 4 out of the 6 pairs would not connect completely to the vg248. The velcro that snaps in the cable to vg248 would not seat completely, causing either the left side or right side to lift slightly and dropping ports. If you press on the cable connector with all your might, it would be up and the port worked fine.
So we replaced the cables with better connectors and it works fine now.
Cisco doesnt recommend a brand, I cant remember off the top of my head, but make sure they are top quality.
