hardware set up
Answered Question
May 15th, 2007
I just connectected comm-server 2511 to 2x 2610 router with async cable 8rj>45.. ethernet 1 goes to R1 and ethernet 2 goes to R2.. now I have 2950 switch that have only console port how do I connect the 2950 switch to the 2511 comm-server since it does not have any ethernet, my console port on 2511 is connected to my pc ..
thanks
Correct Answer by mohammedmahmoud about 10 years 2 months ago
Hi Karim,
I am very glade that you are enjoying your lab :)
Just to refresh you, here you are all that you need on the comm-server:
interface loopback 0
ip address x.x.x.x y.y.y.y
line 1 16
transport input telnet
stopbits 1
and then do the reverse telnet:
telnet x.x.x.x 2nnn
where nnn = the line number, ex: if 8 then nnn = 008.
Before doing this do show line, and make sure that there is no * beside the line before doing this, and if there is a * do clear line x until the * disappear.
Take care and enjoy, and i am waiting for your next question :)
HTH,
Mohammed Mahmoud.
You are always welcomed :)
First use the CAB-OCTAL-ASYNC cable to connect all your devices to the comm-server to have console access to all your devices, afterwards we can discuss your lab needs and topology.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Use one of the Async interfaces from the comm-server to connect to the console port of the 2950.
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (5 ratings)
Correct Answer
mohammedmahmoud Tue, 05/15/2007 - 12:12
  • Green, 3000 points or more
HTH,
Mohammed Mahmoud.
cisco steps Tue, 05/15/2007 - 12:23
hi again mohammed
what cable should I use ? it looks like the async interface have more pins. is this some combination of cable that I need to use..
mohammedmahmoud Tue, 05/15/2007 - 12:42
You should be using the CAB-OCTAL-ASYNC cable, and since the CAB-OCTAL-ASYNC cable is itself rolled, you can connect each cable directly to the console ports of devices with the RJ-45 interfaces.
Mohammed Mahmoud.
cisco steps Tue, 05/15/2007 - 12:58
Thanks .. I did that .. but when I do show cdp neighbors detail , I am not seeing anything . I get
2511sw#show cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater
Device ID Local Intrfce Holdtme Capability Platform Port ID
am I suppose to see R1 and 2950sw ? or this require more config ON ( R1 and 2950sw )
mohammedmahmoud Tue, 05/15/2007 - 13:07
CDP don't run over console ports, accordingly it won't show CDP neighbors in this manner.
Mohammed Mahmoud.
cisco steps Tue, 05/15/2007 - 13:11
lol.. thanks MO. you know that I was comming with more questions here it is ...
how I am suppose to connect to those router ?
I was going to create new conversation on since you already answered my hardware question..
Correct Answer
mohammedmahmoud Tue, 05/15/2007 - 13:19
Mohammed Mahmoud.
cisco steps Tue, 05/15/2007 - 13:35
just to let you know Mo . I just find out from last notes that I need to configure the loopbac0 Interface.. I am in the porocess of doing that ... hope things will work .. Thanks for you help
karim
Correct Answer
mohammedmahmoud Tue, 05/15/2007 - 13:40
Hi Karim,
line 1 16
stopbits 1
telnet x.x.x.x 2nnn
HTH,
Mohammed Mahmoud.
cisco steps Tue, 05/15/2007 - 13:58
Hey Mo
here is what I did
interface loopback 192.168.10.10 255.255.255.0
line 1 16
line transport telnet
2511sw#telnet 192.168.10.10 2001
Trying 192.168.10.10, 2001 ...
% Connection refused by remote host
I did ip host r1 2001 192.168.10.10
..stillgeting the same error..
I did clear line 1
still getting * on 0 1 and 2
2511sw#show session
% No connections open
2511sw#
mohammedmahmoud Tue, 05/15/2007 - 23:26
Hi Karim,
Please past your entire configuration, show ip interface brief and sh line.
BR,
Mohammed Mahmoud.
cisco steps Wed, 05/16/2007 - 13:44
Mo . you know I add no exec.. to the config and now I am able to connect to r1.. I am not near the lab today .. but will let you know if any questions ..
thanks /
mohammedmahmoud Wed, 05/16/2007 - 13:55
Hi Karim,
I am glade it worked out, but this is not logical as "no exec" is just used for security measures ensuring that the line never becomes unavailable due to a rogue EXEC process (To insure that unwanted signals from the attached device can't launch an EXEC session to the comm-server).
Please use this document as a reference, and please never hesitate for further questions:
Configuring a Terminal/Comm Server
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a008014f8e7.shtml
And again, please do enjoy your lab :)
Mohammed Mahmoud.
