pre-classify clarification
May 15th, 2007
I think I have a good understanding of what the pre-classify command does, but I'm having a problem determining where to place it. Can someone explain what happens when the pre-classify command is APPLIED AND NOT APPLIED in these scenarios. In other words, will classification be done on the inside header or the outside.
1. IPSEC Only (No GRE)
-applied on the physical interface
2. IPSEC ONLY (No GRE)
-applied on crypto map
3. IPSEC AND GRE
-applied on tunnel interface
4. IPSEC AND GRE
-applied on physical interface
5. IPSEC AND GRE
Also, what would happen if the pre-classify command is placed in more than one place at a time? Which overrides the other?
