Bridging on a 2811 router
May 15th, 2007
We are in the process of replacing our existing 3com bridges with a cisco 2811 router with a channelized t1 PRI interface. Is it possible to program different bridge groups that would be assigned to different channel-groups on the PRI interface as then the 2811 could replace the 5 existing bridges now in place. If so, could you provide a brief explanationas to how. THanks in advance.
Anonymous (not verified) Mon, 05/21/2007 - 10:54
The Cisco 2811 provides significant additional value compared to prior generations of Cisco routers at similar price points by offering up to a fivefold performance improvement, up to a tenfold increase in security and voice performance, embedded service options, and dramatically increased slot performance and density while maintaining support for most of the more than 90 existing modules. Wire-speed performance for concurrent services such as security and voice , and advanced services to multiple T1/E1/xDSL WAN rates.
If you want to know more please click Below URLs:
