Multicast Traffic generator
May 15th, 2007
Can anybody suggest an Multicast Traffic generator(Free window based tool) to test the MVPN solution over MPLS backbone.
Thanking You
Anantha Subramanian Natarajan
Overall Rating: 4 (4 ratings)
anasubra_2 Tue, 05/15/2007 - 13:11
Hritter,
Thank you very much . But I guess , I am not sure how to use that :) .....I downloaded the source code for windows named iperf-1.7.0-win32 and extracted the same. There is an exe which I when clicked on it opened an DOS prompt for some seconds and automatically closed itself.
Am I looking into the right file ?
Kindly assist me on the same
Thanking You
scottmac Tue, 05/15/2007 - 13:18
  • Green, 3000 points or more
We used to use things like iTunes and various music & video sharing and similar in class.
The basic exercise was "get multicasting working, and you can listen to music (or watch videos)"
Good Luck
Scott
Harold Ritter Tue, 05/15/2007 - 13:36
  • Cisco Employee,
Anantha,
Once you open your DOS shell, you can start "Iperf --help" to see all the flags and parameters you can set.
Hope this helps,
royalblues Wed, 05/16/2007 - 00:13
Scott,
How was your setup... I have tried sharing Mp3 files over multicast but was never successful
Narayan
johnd2310 Mon, 05/21/2007 - 20:23
  • Silver, 250 points or more
Try vlc to stream video or music
regards
John
edondurguti Fri, 05/25/2012 - 14:39
Run EIGRP if it works it works
or get     VLC and stream a file to a multicast address on a windows/linux machine, then play the multicast from another machine using vlc... ps. just before finishing the stream setup if you use gui add a time to live ttl=12 or something, cuz it's 1 by default.
