PIX 501 GUI admin
When I try to load the PIX GUI admin it does not load without an internet connection being present. Is there anywhere I can download the PIX admin program (ver 3.0) so that I can configure a PIX that is on a purely private network without internet access?
It would also be great for checking on a PIX box when the internet connection is non functional.
mfreijser Wed, 05/16/2007 - 01:41
  • Bronze, 100 points or more
Do you try to contact the GUI via the outside interface or the inside interface? If you try to do it via the outside interface, it sure won't work when there is nog internet connection present :)
Michael
I allways do the GUI connection from the inside interface.
This week we had issues with internet connection - it turned out to be a broken switch at the ISP's facility. The problem is that when the internet is down the GUI will not load. It seems to load from the Cisco site.
Is there anyway of getting the Java applet and running what would otherwise be downloaded froma local PC?
I am sure others have this problem also!
