2511 reverse telnet
Answered Question
May 15th, 2007
Hi again . now I was able to get from comm-server 2511 to 2610 when I canfigured the loopback0.. now I wan to getback to 2511 com-serv its says on the doc that I need to do Ctrl+shift 6, twice// I did but I am still on the R1 PROMT
do I need to config a loopback0 on 2610 so it will go back to 2511.. ?
Correct Answer by CSCO10892433 about 9 years 10 months ago
Please follow these steps
1. Press the keys "Ctrl","shift","6" at the same time.
2. Release the above keys.
3. Hit the key "x"
Hope this works. If not, let me know.
SSLIN
Type "Ctrl+shif-6" then "X"
SSLIN
Overall Rating: 4.7 (3 ratings)
Correct Answer
CSCO10892433 Tue, 05/15/2007 - 15:28
  • Silver, 250 points or more
SSLIN
cisco steps Tue, 05/15/2007 - 15:38
you mean hit the key Ctrl+shif-6 the letter X or type it ..
Correct Answer
CSCO10892433 Tue, 05/15/2007 - 15:48
3. Hit the key "x"
SSLIN
cisco steps Wed, 05/16/2007 - 13:49
thanks will try and let you know, not near the lab today/
cisco steps Fri, 05/18/2007 - 06:35
I was able to got from 2511 to R1.. I did what its says .. but i does not work.
R1#x
% Ambiguous command: "x"
R1#xR1#x
R1#show session
% No connections open
R1#show sessions
cisco steps Fri, 05/18/2007 - 06:40
I was able to firuge it out.. I guess I ahve to be on enable user mode.. then apply the command ..
Thanks for the help
R1#disable
R1>
2511sw#
CSCO10892433 Mon, 05/21/2007 - 00:32
Hi, ocporbust
That sounds strange. I had used this command for thousands times. It worked no matter the router was on user mode or exec mode.
Would you please try it again?
SSLIN
cisco steps Sun, 05/27/2007 - 07:29
sorry for the delay of my response, I did it this time and it did work from the ex mode.. Thanks
