what benefit for SAM module?
Answered Question
May 15th, 2007
Greeting.
After few reading, I still feel hardly to decide if we need SAM module on my CSS11506 (v8.10) or not.
Could anyone advice me, for what situation I need a SAM ?
Any comments will be appreciated
Thanks in advance
Correct Answer by joquesada about 10 years 1 month ago
The SAM module was created to allow the CSS to support more load without forcing the user to consider an upgrade in the hardware. For example, normally a CSS 11506 with an SCM, an IOM and an SSL module would be able to support around 500.000 simultaneous flows, if you add a SAM module, this number might increase to 750.000 or 1.000.000.
Consider the SAM module as a booster for the CSS, as it was created to add more horse power to the CSS. In order to consider if you need it or not, you need to consider how much load you want to put on the CSS. Thanks!
I hope this helps.
Jose Quesada.
Overall Rating: 5 (1 ratings)
Correct Answer
joquesada Tue, 05/15/2007 - 20:00
  • Bronze, 100 points or more
I hope this helps.
Jose Quesada.
