NIST Net WAN Emulation Software question
May 15th, 2007
Hi all,
I have just installed the NIST software and it comes up fine, but I was wondering what I have to do to get it to recognize all of my network interfaces? I have a total of 5 with an on-board interface and an added 4-port NIC installed. Cureently, the software only recognizes eth0 and eth1 (the first two interfaces on the 4-port card) It does not recognize the onboard interface nor the remaining two add-on interfaces.
Thank you.
vkapoor5 Mon, 05/21/2007 - 10:59
  • Bronze, 100 points or more
It looks like NIST only supports 2 NICs.
snakayama Tue, 05/22/2007 - 21:19
According to the "Frequently Asked Questions about NIST Net" (http://www-x.antd.nist.gov/nistnet/faq.html),
it looks like NIST Net works between two subnets (two interfaces).
The following is the relating matter excerpted from above FAQ.
Q. What do I need to run NIST Net?
One or more network interfaces. Typically, NIST Net is installed on a box with two Ethernet cards which is routing between two subnets. This allows it to munge all traffic flowing between the two networks.
jchristn Thu, 05/24/2007 - 22:18
Did you try doing an 'ifup eth2', and the same for eth3, eth4, and so on? NISTnet is running on top of Redhat, so the process/procedures for managing interfaces is identical.
Best regards,
Joel
