CME attendant console "lite" application?
May 15th, 2007
Does anyone know of Windows-based software that will act as a busy lamp field for up to 100 phones in a CallManager Express environment and (as a secondary requirement) provide simple attendant console capabilities?
We are running a trial of Arc Solutions' ArcExpress software, and while it looks to be excellent software, it's overkill for this install. It's very restrictive on how the receptionist's phone must be configured, and it pretty much requires you to use the PC to handle all calls.
There are 75+ phones in this office, so a couple of 7914's wouldn't be enough.
paolo bevilacqua Fri, 06/08/2007 - 15:34
  • Hall of Fame,
    Founding Member
Standby, I'm working on something. I would appreciate if you can send me the requirements to the email address in my profile.
