CME DID range conflicts with Operator "0"
May 15th, 2007
I have a customer that is migrating from another PBX to a Cisco CME/CUE scenario. The DID range happens to begin with "0" (usually operator's extension) for example the DID range last 4 digits are 0200-0299. In the old PBX the extensions were configure with a 3 digit extension and I assumed they did this because of the conflict. I know I can recommend to the customer to continue to use this scenario in order to facilitate access to the operator by dialing "0" from CUE AA or internally from the IP Phones. Do you know any other way in which this can be overcome or configured in a better way?
Armando.
paolo bevilacqua Wed, 05/16/2007 - 03:29
  • Hall of Fame,
    Founding Member
Hi Armando,
Even if telco is sending four digits, I think in you case the range is actually three digits. So I would recommend to keep the previous scheme of three digits extension and this will make everything easy.
aramos17428 Wed, 05/16/2007 - 06:13
Mr P.
Thanks for the reply. Thas't what I thought
I will try to keep it within the 3 digit range.
Armando.
