Install LMS
May 15th, 2007
I am now planning to do fresh install for LMS 2.6 to new server. I check the Quick start guide for LMS and there is entry "LMS supports only the US english anf Japanese versions of these operating systems. Set the default locale to US-English for the US-English versions." Does that mean that i have to change from control panel under regional options icon the General "Your Locale" to English(United States) before i start to install LMS. Is that enough or should i change somenthing else E.g. Input locales
Juha
Overall Rating: 3.5 (2 ratings)
David Stanford Wed, 05/16/2007 - 03:43
  • Cisco Employee,
Yes, you need to change your regional settings to US English under here...make sure everything is set to US English or Japanese.
Martin Ermel Wed, 05/16/2007 - 03:54
  • Blue, 1500 points or more
but it is not necessary to set the input locales to US English or Japanes
Joe Clarke Wed, 05/16/2007 - 07:30
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can have as many keyboard layouts and input locales configured as you'd like. However, when entering data into LMS fields in your browser, you need to generally use 7-bit ASCII. If not, >= 8-bit characters can be transformed into '?'. This may cause unexpected results (i.e. in Netconfig) when used by the application.
