ISDN backup stay connected
May 15th, 2007
Hello! I have 3 routers. 2 of them are connected over frame relay and third router is used for backup. All 3 using eigrp and backup router is using static floating route to make backup. The problem is that ISDN stay connected when frame relay become up.
Overall Rating: 5 (1 ratings)
fisko Wed, 05/16/2007 - 02:08
Well The interesting traffic exclude eigrp updates
Here is the acccess list for dialer-group
access-list 115 deny eigrp any any
access-list 115 permit ip any any
The thing is that isdn backup is not on the same router where is primary link. It seems that backup router does not get the eigrp update about new primary route.
I don't think that the problem is that the backup router is notified about the primary route, because if there is no traffic through it there is no need for the ISDN to stuck. The ISDN will go down after the idle timeout. There must be some traffic which keeps it active. A config would be helpful together with show ip route output. The reason why the primary route is not installed with eigrp is might be the floating static route metric is less than 90 or 170 (depends how the prefix is annonced through eigrp). So the floating static will have higher preference over eigrp route, but if the isdn goes down the eigrp route should be put in the routing table.
fisko Wed, 05/16/2007 - 22:26
Here is the configuration .....
BACKUP ROUTER
interface BRI0
ip address XXXXXXX
encapsulation ppp
no ip mroute-cache
dialer idle-timeout 180
dialer map ip REMOTEIP name REMOTE broadcast NUMBER
dialer load-threshold 5 either
dialer-group 1
isdn switch-type basic-net3
ppp authentication chap
ppp multilink
router eigrp 20
redistribute static
network XXXXXX LANS
network XXXXXX WANS (include ISDN and FRAME RELAY)
no auto-summary
no eigrp log-neighbor-changes
ip route REMOTE LAN 200
dialer-list 1 protocol ip list 115
REMOTE ROUTER
interface BRI0
ip address XXXXXXX
encapsulation ppp
no ip mroute-cache
dialer map ip BACKUPIP name BACKUP broadcast
dialer-group 1
ppp multilink
router eigrp 20
network XXXXXX LANS
no auto-summary
ip route CENTRAL LAN 200
access-list 116 deny eigrp any any
access-list 116 permit ip any any
dialer-list 1 protocol ip list 116
Which router is the default gateway for the hosts on the central LAN? If you can post the whole config of the 3 routers that would be fine.
Let's try to remove the network XXXXXX WANS (include ISDN and FRAME RELAY) from the backup router and enable eigrp for only to the FR link. You have static route in both side for the LAN's so no need to run eigrp through the ISDN.
fisko Wed, 05/16/2007 - 23:53
It is little complicated.....I use route summarization on wans and ISDNS with one B class and remote and local LANS other B class.
How is your LAN connected on the central site to the two routers. Which router is the default gateway. A full config from both routers would be still helpful. I think it is a routing issue, because after the ISDN brought up the traffic is still goes through it even if the primary link will come up. Let's check the routing first.
fisko Thu, 05/17/2007 - 02:34
You have example with pseudo IP
....just example
so conf is
ROUTER2
interface eth0
ip address 192.168.100.2/24
interface BRI0
ip address 192.168.4.1/24
encapsulation ppp
no ip mroute-cache
dialer map ip 192.168.4.2 name REMOTE broadcast NUMBER
dialer-group 1
ppp multilink
router eigrp 20
redistribute static
network 192.168.0.0
no auto-summary
ip route 192.168.2.0 255.255.255.0 200
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ROUTER3
interface etho
IP address 192.168.2.1/24
int ser0
ip address 192.168.3.2
interface BRI0
ip address 192.168.4.2/24
encapsulation ppp
no ip mroute-cache
dialer map ip 192.168.4.1 name BACKUP broadcast
dialer-group 1
ppp multilink
router eigrp 20
network 192.168.0.0
no auto-summary
ip route 192.168.1.0/24 bri0 200
ROUTER1
interface etho
IP address 192.168.100.3/24
int ser0
ip address 192.168.3.1
router eigrp 20
network 192.168.0.0
no auto-summary
ROUTER
eth0
ip address 192.168.100.4/24
eth1
ip address 192.168.1.1/24
router eigrp 20
network 192.168.0.0
This is the logic........of the conf......
See the picture
THANKS
fisko Thu, 05/17/2007 - 03:53
No i dont use the 192.168
this is just
an example the 192.168.....in my case is B class adreses
fisko Thu, 05/17/2007 - 05:06
how to increase delay under bri and eigrp metric with hold down timmers?
As eigrp by default confider only bandwidth and delay of the path you have two choices to influence the metric. The holddown timer is to how long
interfacew bri0
delay 2000
bandwidth 40
If you take a look to the show ip eigrp topology x.x.x.x/y you will see it.
Anyway the hold-down timer is to detect the neighbor is dead and not used for the metric calculation. Hope it helps
fisko Thu, 05/17/2007 - 22:16
If I put the bandwidth 40 will this decrease speed on logical level.....on ISDN? Or is it a just used for best route calculation?
fisko Fri, 05/18/2007 - 00:37
Here is the EIGRP topology and neigbors after all link are up
BACKUP ROUTER
EIGRP Neighbour
D 172.20.91.0 [90/40514560] via 172.30.30.2, (this is ISDN IP)
EIGRP Topology
P 172.20.91.0/24, 1 successors, FD is 40514560
via 172.30.30.2 (40514560/28160), BRI2/7
FRAME RELAY ROUTER
EIGRP NEighbor (It puts ISDN router in eigrp table not serial link)
D 172.20.91.0 [90/40517120] via 172.30.100.3, 00:02:57, FastEthernet1
EIGRP Topology
P 172.20.91.0/24, 1 successors, FD is 40517120
via 172.30.100.3 (40517120/40514560), FastEthernet1 (This is eigrp route over ISDN ROUTER )
via 172.30.160.2 (297246976/28160), Tunnel1
(This is EIGRP route over frame relay that is encapsulated in GRE)
What to configure on ISDN BACKUP router and Frame relay router in order to get
As primary EIGRP route....
It seems that tunnel traffic have a big delay so ISDN is brinnging up and say up
You didn't mentioned so far there is a GRE tunnel through the FR link.
In this case eigrp will calculate the metric based on the bandwidth and delay of the tunnel interface.
Let's set the bandwidth under tunnel interface to much higher than on bri. What's the cir of the FR link? Anyway why do you use GRE over FR? It just introduce additional overhead.
fisko Fri, 05/18/2007 - 01:51
It is little complicated......this is not real point to point frame relay........I must have VPN for solution and also want to use EIGRP as my routing protocol in topology.....so i encapsulate EIGRP in GRE.... CIR is 512 Kbps
fisko Fri, 05/18/2007 - 01:52
I have also few same EIGRP....GRE...ISDN static floating combinations and they working fine....just this one making a problem....
So the problem is with GRE is that its default bandwidth is 9kbit/s and the delay is also very high.
For instance:
Tunnel0 is up, line protocol is down
Hardware is Tunnel
MTU 1514 bytes, BW 9 Kbit, DLY 500000 usec,
So let's change it to 512 and if needed reduce the delay here or increase the delay on bri.
You will see how the FD changed on the ROUTER using the show ip topology.
You have to alter these values until the route table will be changed.
Another solution is to use eigrp offset list to anounce the remote LAN prefix with much higher delay but now try the above.
fisko Fri, 05/18/2007 - 02:58
THANKS A LOT! Give You the feedback!
