Crypto map config
Answered Question
I would like to know whether we can configure more than one crypto maps on a single interface?
Correct Answer by Jon Marshall about 10 years 2 months ago
You cannot use more than one crypto map on an interface but you can use separate entries within the same crypto map ie.
crypto map vpn-set 1 ipsec-iskamp
crypto map vpn-set 1 set peer x.x.x.12
Your next VPN would be
crypto map vpn-set 2 ipsec-isakmp
crypto map vpn-set set peer y.y.y.15
etc.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 05/16/2007 - 02:49
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
etc.
Jon
