PIX 525 6.3(5) mem req. FLAH and RAM
May 16th, 2007
Need to know exactly the requirements of flash and ram for upgrade the PIX 525 to version 6.3(5).
As you can see there're 2 different statements:
1)PIX 6.3(5) RELEASE NOTES:
http://www.cisco.com/en/US/docs/security/pix/pix63/release/notes/pixrn635.html#wp31988
Table 1 Flash Memory Requirements
PIX 525 16 MB
2)PIX SOFTWARE DOWNLOAD:
http://www.cisco.com/cgi-bin/tablebuild.pl/pix
pix635.bin
PIX OS version 6.3(5) software.
Requires a minimum of 8 MB Flash and 16 MB RAM.
07-SEP-2005
2101248
srue Wed, 05/16/2007 - 05:14
  • Blue, 1500 points or more
unless you have less than 8MB of flash, you should be ok there. I would be very surprised also if your 525 had less than 16 MB of RAM.
I've used 6.3(5) on PIX'es as small as a 501 and 506e.
prabhusworld Mon, 06/18/2007 - 07:23
Dear All,
I having a PIX 525-UR-BUN, In that i am having 1 inside and 1 outside Port, Now i want 3 Inside Port and 3 Outside Port. Is there is anything to buy more for me. what i want to buy.
Thanks & Regards
Prabhu
