AXL: HTTP-Socket needs to be initiated for every packet?
May 16th, 2007
may be this is a little off-topic:
I use Java to program AXL-API.
Example: addRoutePattern. I would like to add 20 route pattern to CM.
Is there a chance to open a http-socket (once), send the route patterns and close it?
As far as my experience is, it is not. I have to build for every route pattern an SOAP-packet and it is not successfully, when I don't close the socket after every packet ...
Any ideas?
Thanks in advance
Axel
Sascha Monteiro Thu, 05/17/2007 - 11:07
  • Silver, 250 points or more
I am doing the same with Java, but the CCM closes the socket, you cannot keep it open.
(not sure if you can with "normal" SOAP interfaces...)
It gives a bit of overhead, but if you do writes you should not do more than 60/min anyway.
Even with the overhead of setting up the socket, I still need to throttle my POSTs to the AXL SOAP API..I had to do 2500 routepatterns
stephan.steiner Mon, 05/21/2007 - 00:47
2500 RPs? Geez. And I thought my couple hundred was a lot. I actually wrote my axl class lib to automatically wait 10 seconds if it gets the appropriate http repsonse.. that way I can rapid fire and the server throttles my requests.
I guess the question of whether you can keep the socket open or not comes down to what HTTP standard the server supports - it takes HTTP 1.1 to keep a socket open.
schemberg Mon, 05/21/2007 - 00:53
... we can beat 2500. We have about 60 clusters with about 60 patterns each = 3600.
One more question: Is it possible to send more than one pattern inside of one SOAP-request?
I thought "sequence" seems to be a hint, that this is possbile, but when I tried to do so, it only accepts the first pattern (:-((
Thanks in advance
Axel
