vlans using ospf
May 16th, 2007
If I have 3 routers with vlans configured, do i just have to include the vlan ip address into the routing statement, and make sure the other router has at least 1 ip address in the same vlan, then this should recieve info about other vlans in the switch
vladrac-ccna Wed, 05/16/2007 - 07:28
hello Carl,
how are you doing?
may I ask you something. Ive noticed that you've been posting here for a long time.
Are you studying network ?
Anyway...you need to be more specific when asking this kind of question.
There're many issues with OSPF.
Usually if you have 3 routes connected via some ethernet interfaces. its just a matter of setting the networks on area 0 and you're good to go.
But again, its a bit hard to understand your question.
