RDP fails
Answered Question
May 16th, 2007
I have a 501 with a VPN set up. Once the VPN is established, I rdp to an internal server. Usually, I have no problem; I can connect repeatedly from either my desktop or laptop computers.
The problem is that after another user connects RDP and disconnects, RDP is no longer available for any users. What I usually do is go in and reload the configuration. The vpn still works but RDP cannot go across it. My config is as follows:
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
clock timezone EST -5
clock summer-time EDT recurring
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol pptp 1723
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list 101 permit ip 10.1.1.0 255.255.255.0 192.168.2.0 255.255.255.0
pager lines 24
logging on
mtu outside 1500
mtu inside 1500
ip address outside X.X.X.X 255.255.255.0
ip address inside 10.1.1.1 255.255.255.0
ip verify reverse-path interface outside
ip verify reverse-path interface inside
ip audit info action alarm
ip audit attack action alarm drop
ip local pool 10.1.2.32-10.1.2.62 255.255.255.0
ip local pool ip 10.1.2.32-10.1.2.60 mask 255.255.255.0
pdm location 10.1.1.32 255.255.255.255 inside
pdm location 10.1.1.2 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 X.X.X.1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.2.0 255.255.255.0 inside
http 10.1.1.32 255.255.255.255 inside
http 10.1.1.2 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
tftp-server inside 10.1.1.32 c:\cisco
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp nat-traversal 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup vpn address-pool ip
vpngroup vpn dns-server 10.1.1.2
vpngroup vpn wins-server 10.1.1.2
vpngroup vpn split-tunnel 101
vpngroup vpn idle-time 1800
vpngroup vpn password XXXXXXXX
telnet 10.1.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
management-access inside
console timeout 0
dhcpd auto_config outside
terminal width 80
Correct Answer by acomiskey about 9 years 11 months ago
I don't see how the vpn works at all. Your acl 101 for nat exemption and split tunnel is not correct. It should be...
access-list 101 permit ip 10.1.1.0 255.255.255.0 10.1.2.0 255.255.255.0
add additional inside networks as required...
access-list 101 permit ip 10.1.2.0 255.255.255.0
Overall Rating: 5 (1 ratings)
Correct Answer
acomiskey Wed, 05/16/2007 - 07:40
  • Green, 3000 points or more
peteb41976 Wed, 05/16/2007 - 09:03
This seems to be working - Let's hope it stays that way...
enable password XXXX
names
pager lines 24
logging on
mtu outside 1500
mtu inside 1500
ip address outside XXXX 255.255.255.0
ip local pool ippool 10.1.2.32-10.1.2.60 mask 255.255.255.0
pdm location 1.2.3.5 255.255.255.255 inside
pdm location 192.168.1.95 255.255.255.255 inside
pdm location 192.168.1.0 255.255.255.0 inside
pdm location 10.1.1.0 255.255.255.0 inside
pdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 X.X.X.X.
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
acomiskey Wed, 05/16/2007 - 09:13
So you aren't experiencing the weird rdp issue now?
please rate if it helped.
