SSH on 6509 8.1(3)???
Answered Question
May 16th, 2007
Hi all, I need to configure SSH on a 6509 running 8.1(3). I just wanted to know if SSH is supported?
Any help would be greatly appreciated.
Brian B.
Correct Answer by ankbhasi about 9 years 8 months ago
Hi Brian,
I am attaching the same doc as .pdf file and you can download from this post.
Ankur
*Pls rate all helpfull post
Overall Rating: 4 (1 ratings)
brianburyak Wed, 05/16/2007 - 08:10
I wasnt able to login to the website, it asked for cisco user name and password, i have CCO account but it didnt let me in :(
glen.grant Wed, 05/16/2007 - 15:23
You have to have the K9 image of catos software to run ssh . If it is a K8 image it is not supported . Also catos does not have a built in ssh client which means you cannot ssh from a catos box to another ssh device . Any catos image that has K9 as part of its name should support ssh.
brianburyak Wed, 05/16/2007 - 17:26
Glen thank you, that was exactly what i wanted to know.
Brian Buryak
