ASA 5520 VPN Support
May 16th, 2007
From the datasheet for the ASA5520 VPN model, I know it supports 750 concurrent connections.
Can anyone tell me, does the device have a limit on how many separate connections (i.e. users) can be made to the device?
e.g. can I have 7,000 users registered to connect to a 5520, as long as only a max of 750 are connecting concurrently?
Overall Rating: 5 (1 ratings)
hoogen_82 Wed, 05/16/2007 - 08:37
  • Silver, 250 points or more
Yes, thats exactly what would happen. But my suggestion would be not to touch that 750 limit that's put up on the data sheet have a limit of probably around 600-675. You probably could get into performance related issues.
Hoogen
Do rate helpful posts :)
