Configuring Priority Queueing on Multilink PPP interface
Answered Question
May 16th, 2007
I have one Cisco 7206VXR (NPE-G1) with IOS version 12.3(17b) and using QoS Priority Queueing on Multilink PPP interface.
The ACL number 100 doesn?t have match, then, the QoS isn?t operating.
Do you have idea the issue? Will be IOS bug or configuration?
OBS: It follows attached configuration.
Correct Answer by bjornarsb about 10 years 2 months ago
Like this:
class-map match-all yellow
match qos-group 3
class-map match-all blue
match qos-group 2
policy-map clients
class blue
priority XX
class yellow
priority XX
crypto isakmp profile blue
match identity group cisco
client authentication list autho
isakmp authorization list autho
client configuration address respond
qos-group 2
crypto isakmp profile yellow
match identity group yellow
match identity address 10.0.0.11 255.255.255.255
qos-group 3
crypto dynamic-map mode 1
set security-association lifetime seconds 180
set transform-set client
set isakmp-profile blue
reverse-route
crypto dynamic-map mode 2
set transform-set combo
set isakmp-profile yellow
reverse-route
interface FastEthernet0/0
ip address 10.0.0.110 255.255.255.0
no ip redirects
no ip proxy-arp
no ip mroute-cache
duplex half
no cdp enable
crypto map mode
service-policy out clients
BR,
Bjornarsb
Overall Rating: 4 (1 ratings)
bjornarsb Wed, 05/16/2007 - 10:00
  • Bronze, 100 points or more
Keep in mind that using esp encrypts your IP.
You must do QOS like this:
qos-group 2
Bjornarsb
fjmendonca Wed, 05/16/2007 - 10:30
But if I to configure in this way I obtain to use PQ (Priority Queueing)?
Thank you,
Fabiano
royalblues Wed, 05/16/2007 - 11:10
  • Green, 3000 points or more
Generally when you have encryption, QoS pre classification is used.
under the crypto map configurtion add
QoS pre-classify.
I do not know whether this will work with priority list but it works fine when you use class based QoS and running encryption
HTH, rate if it does
Narayan
Correct Answer
bjornarsb Wed, 05/16/2007 - 12:41
Like this:
match qos-group 3
match qos-group 2
policy-map clients
class blue
priority XX
class yellow
priority XX
qos-group 2
qos-group 3
reverse-route
reverse-route
no ip redirects
no ip proxy-arp
no ip mroute-cache
duplex half
no cdp enable
crypto map mode
BR,
Bjornarsb
