b.speltz Tue, 05/22/2007 - 06:40
  • Bronze, 100 points or more
similar cases the manual uninstall procedure solved the issue , if it not helps try following:
Uninstall the TCP/IP on Windows.
Disable any Antivirus and/or Firewall before and during trying to install the VPN Client.
