Secondary IP Addresses
jw4517
I have a 3825 that is connected to a 10Mbps Metro-Ethernet Internet connection to the POP GE0/0. I have two global IP address blocks. The first global IP address block is configured on the GE0/1 interface while the 2nd global IP address block is configured on the GE0/1 interface as secondary.
Global IP Address Block gets a full 10Mbps upstream and dwonstream but the 2nd IP block gets 5Mbps.
Has anyone ever heard of this problem before?
thanks,
bjornarsb
Level 4
Level 4
I quess if you make sure that noone is using Internet in the first global block
(or disable it), you will get 10 Mbps using the second scope too.
Bjornarsb
