paolo bevilacqua Wed, 05/16/2007 - 09:29
  • Hall of Fame,
    Founding Member
Which type/speed the wan links you need ?
paolo bevilacqua Wed, 05/16/2007 - 10:21
  • Hall of Fame,
    Founding Member
you can use a 2811 with nm-16a/s, and hwic-4esw.
Or 3 x hwic-4T instead of nm-16a/s, if you plan to upgrade the links the higher speeds. In this case, a 2801 would suffice.
