PIX running 7.2(2) not allowing access to one website...
We're running 7.2(2) on a PIX 525. We can't seem to access one website. No deny messages show up in the syslog, just a TCP reset message.
2007-05-16 13:40:05 Local4.Info inet-pix May 16 2007 13:40:05: %PIX-6-302014: Teardown TCP connection 673938 for outside:207.46.248.109/80 to inside:10.x.x.x/3777 duration 0:01:01 bytes 1274 TCP Reset-I
I found one article on CISCO's website that referenced an issue with large MSS, but that doesn't seem to be the problem. Any ideas?
Overall Rating: 2 (1 ratings)
zulqurnain Tue, 05/22/2007 - 22:07
  • Bronze, 100 points or more
hello
as what i know and seen, TCP Reset-1 message appears when the remote host rejects or send a malformed packet reply
also did you try connecting from outside to this site at the same time when you had the problem, this might give you a clue.
HTH, please rate it
