Local SPAN
May 16th, 2007
I have eight cisco 6509 switches interconected via EtherChannel's.VLAN 15 exists on each on of them and is in the allowed VLAN list on the etherchannel.
My question is that if i start a local SPAN session ( to capture VLAN 15) on say switch 1,will this session capture the VLAN 15 traffic as seen on other switches aswell.
Thanks!
chris.lepa Wed, 05/16/2007 - 11:11
I'm pretty sure it'll just capture local VLAN 15 traffic. RSPAN is the one that captures remote VLAN traffic.
-Chris
rpsrekhi3 Wed, 05/16/2007 - 11:19
Yeah,i also think that way but the Trunk-Ports ( Etherchannel) also carry VLAN 15.Any possibility that VLAN15 traffic from inter-conected switches also make way in the SPAN session.
chris.lepa Wed, 05/16/2007 - 11:21
Yes, any VLAN 15 traffic recieved on the switch running the local SPAN session will be seen.
If some VLAN 15 traffic travelled from SW2 through SW1, it would be seen.
-Chris
mohammedmahmoud Wed, 05/16/2007 - 11:40
  • Green, 3000 points or more
hi,
Yes only if this traffic reaches the local switch.
HTH,
Mohammed Mahmoud.
