How to contain UDP traffics
Answered Question
May 16th, 2007
Imagine I have devices which muticasts and broadcasts tons of UDP traffic on a given network. Suggested solution is that I should put a router and let the device on the respective network (10.0.0.0/8) installed there. Note that the respective devices are hardcoded to use the 10.0.0.0/8 network. That way when the devices on the 10.0.0/8 broadcasts and multicast massive traffic, the router should block the whole unicast and brodcast traffic.
My question is this, if I connect the respective network devices which broadcast and unicast like crazy in on a Cat 3750 instead of a router, what type of feature or VLAN ACL should I use in order to contain such multicast and broadcast traffic and still allow communication between the devices on the Cat 3750 (10.0.0.8/24) with the corporate network? Is there any direct VLAN ACL I should use, or should I configure IP routing on the Cat 3750 in order to let it route from the 10.0.0.8/24 to the coporate_network? Sorry if this is a stupid question.
Correct Answer by royalblues about 10 years 1 month ago
Yes you are correct.
By default a layer 3 device will block all the broadcast acting as a boundary. In a L3 switch a broadcast would be limited to the VLAN and does not spill over to other VLANS
However te devices can be configured to support multicast in which a particular traffic might be required across a set of VLANs
You would however require ip routing to route between vlans
HTH, rate if it does
Narayan
Overall Rating: 3.7 (3 ratings)
news2010a Wed, 05/16/2007 - 12:41
Let me complement this saying that I am obviously I am aware the switch would contain the broadcast traffic there.
Then if I want that VLAN-All-ports-on-Switch-3750 communicate with my internal network and do not forward any broadcast and unicast, all I would need to do is enabling IP routing and route to the corporate network. Is that right?
Correct Answer
royalblues Wed, 05/16/2007 - 12:53
  • Green, 3000 points or more
Narayan
