mohammedmahmoud Wed, 05/16/2007 - 11:53
Cisco uses smart port for optimized quality of service (QoS), Smartports roles match the appropriate class of service (CoS) and differentiated services code point (DSCP) values to the specific Cisco device connected to the Cisco Catalyst Express 500 Switch.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
paulscowcroft Wed, 05/16/2007 - 12:52
So if my phone frame is encapsulated with a TOS bit 5 then DSCP of the smart port role will pick up this and give EF correct?
Will this work with any device or CISCO CDP only?
mohammedmahmoud Wed, 05/16/2007 - 13:03
Yes it uses CDP, it helps ensure that voice-over-IP (VoIP) traffic takes precedence, most Cisco Unified IP phones include a 10/100 switch with QoS to provide PC desktop connectivity to the network.
Mohammed Mahmoud.
paulscowcroft Wed, 05/16/2007 - 14:44
So what if a non CISCO phone is used that puts out a TOS of 5 in the frame but is not CDP. Can the smart port role(phone and pc) still see a TOS bit 5 and corelate it to DSCP 46 and give that packet precedence?
paulscowcroft Thu, 05/17/2007 - 04:36
The smart port role is the same for even the 2960 correct?
I need a diffinative answer that stating the smart port role will work with DSCP and is reverse compatible as the RFC specification defines back to TOS, and I need to know if the smart port role will only work with CISCO devices and if so why only CISCO devices. Meaning what exactly is the reason it will only work with CISCO devices.
