Notification when Uplinks go down
Answered Question
May 16th, 2007
Whats the easiest way for me to get notifications when the uplinks on my 3560-24T's shutdown/disconnect from each other? Also can the same idea/steps be applied to 3550-12Gs?
I tried turning on logging in the Cisco Network Assistant but I ended up getting notified on every single port status change like when a computer gets rebooted.
Correct Answer by sundar.palaniappan about 10 years 2 months ago
You should be able to disable link status traps on access ports with the interface command 'no logging event link-status. This should filter all the unwanted traps.
SW1-3550(config)#logging trap 5
SW1-3550(config)#int range f0/1 - 23
SW1-3550(config-if-range)#no logging event ?
bundle-status BUNDLE/UNBUNDLE messages
link-status UPDOWN and CHANGE messages
spanning-tree Spanning-tree Interface events
trunk-status TRUNK status messages
SW1-3550(config-if-range)#no logging event link-status
SW1-3550(config-if-range)#int f0/24
SW1-3550(config-if)#logging event link-status
SW1-3550(config-if)#do show run int f0/24
Building configuration...
Current configuration : 119 bytes
interface FastEthernet0/24
switchport mode trunk
switchport nonegotiate
SW1-3550(config-if)#do show run int f0/23
Current configuration : 99 bytes
interface FastEthernet0/23
switchport mode dynamic desirable
Sundar
Overall Rating: 4.8 (5 ratings)
royalblues Wed, 05/16/2007 - 13:50
  • Green, 3000 points or more
Unfortunately all the link up/down status are sent as level 3 syslog messages or errors. This will include both the access as well as your trunk ports between the switches
I dont think there is any specific MIB either for you to get this information to a network management station.
Narayan
Correct Answer
sundar.palaniappan Wed, 05/16/2007 - 14:08
Sundar
Joe Clarke Sat, 05/19/2007 - 15:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
no logging event link-status will filter out syslog messages, but not SNMP traps. To disable SNMP link traps for certain interfaces, you also need the following under each interface:
no snmp trap link-status
ricky-li Fri, 05/25/2007 - 11:11
Thanks everyone, the SNMP traps actually worked easier than the syslogs because I'm using intermapper the traps got sent out automatically once they were received.
ricky-li Fri, 05/25/2007 - 13:23
its' working too great, does anyone know what this means all the switches are generating these messages at some random interval:
05/25 11:12:45: Message from InterMapper 4.5.5
Event: TRAP
Document: 1164-C1-switches
Address: 10.10.21.13
Probe Type: SNMP MIB-II (port 161 SNMPv1)
Condition: SNMPv2-SMI::enterprises.9.0.1 (v2c) {
SNMPv2-SMI::enterprises.9.2.9.3.1.1.1.1 : "5",
TCP-MIB::tcpConnState.10.181.69.64.23.10.8.29.128.55297 : "5",
SNMPv2-SMI::enterprises.9.2.6.1.1.5.10.181.69.64.23.10.8.29.128.55297 :
"78624", SNMPv2-SMI::enterprises.9.2.6.1.1.1.10.181.69.64.23.10.8.29.128.55297
: "729", SNMPv2-SMI::enterprises.9.2.6.1.1.2.10.181.69.64.23.10.8.29.128.55297
: "17219", SNMPv2-SMI::enterprises.9.2.9.2.1.18.1 : "" }
Time since last reported down: N/A
Device's up time: 27 days, 21 hours, 4 minutes, 4 seconds
Joe Clarke Fri, 05/25/2007 - 13:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is a tcpConnectionClose trap. It indicates a TCP (most likely a telnet) session has closed. You can disable these traps by removing the "tty" keyword from your trap config.
