May 16th, 2007
Is BGP not included in all IOS images I just bought a new 2811 router and it says bgp is not in this image.
Overall Rating: 3.7 (3 ratings)
franklinmark Wed, 05/16/2007 - 11:57
When I try to type
Router BGP
I get an error message stating that the protocol is not included in this image
mohammedmahmoud Wed, 05/16/2007 - 12:01
This means that your image is most probably an IP Base image, you'll need to download at least a SP image.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
royalblues Wed, 05/16/2007 - 13:09
Though Mohammed is right that all SP eservices image would support BGP, this is not the only feature set you would be looking for to run BGP.
The advance IP services and Enterprise service feature set also support BGP.
The advance security feature set did not support BGP but beginning with 12.4(4)T BGP support was added to this feature set..
Use the feature-navigator to see the features supported by your IOS
HTH, rate if it does
