IOS IPS
ymzhang Wed, 05/16/2007 - 14:56
First, please take a look at http://www.cisco.com/en/US/products/ps6634/products_white_paper0900aecd805c4ea8.shtml.
In summary, the copy command follow the following process:
1. load signature from outside server
2. parse it and read into memory
3. save out to the directory configuration as the ips location, in normal cases, it would be the router flash.
When save the files out, it will save into multiple files in a compressed format, even it has a .xml extension, it is compressed.
Here are the files got saved out:
. -sigdef-typedef.xml
type definition files, defines the engine parameters etc.
. -sigdef-category.xml
signature category file. Just a mapping file map the category to signature IDs
. -sigdef-default.xml
Signature file. Contains all signatures and their parameter definitions
When management by CSM/SDM, it also will save out couple of other files:
. -sigdef-delta.xml
Contains all signature modification information other than the default in sigdef-default.xml
. -seap-delta.xml
Contains all the SEAP configuration changes
. -seap-typedef.xml
SEAP type definition file.
-Chris
ymzhang Thu, 05/17/2007 - 10:40
The current pkg file posted on Cisco.com is not compress and you can see the content as it is a standard xml file. When the router saves them on the router flash, it got compressed to save router flash space.
In the furture, the pkg file might be compressed.
-Chris
