2800 router connected to a 2950 or 2960 switch
May 16th, 2007
What I have been seeing is a site will loose power and then after the equipment is back up the E/N switch port will be blowing errors. The only way I have been able to clear this is by resetting the switch. Any suggestions.
spremkumar Wed, 05/16/2007 - 19:04
  • Red, 2250 points or more
Hi Simmons
When the power goes off is your Switch still on and working ?
Also not sure about E/N switch port as you have mentioned over here..
What about the other end of the switch port ?
Did you try monitoring the other end too ?
regds
