2800 ISR, PVDM2-32, and PRI
May 16th, 2007
Anyone in the mood for network validation check? I'm putting together the following.
Router would be 2800 ISR, CME, CUE, PVDM-32, FXS for Fax Machine, and VWIC 2MFT-T1 where one port would be PRI to PSTN. My question is, the DSP on PVDM-32 is enough to support 32 G.711 Channels. The PVDM-32 DSP will allow me to use one of the VWIC ports for PRI to the LEC? Or is the PVDM only intended for FXO cards?
Mark
Overall Rating: 5 (1 ratings)
thisisshanky Wed, 05/16/2007 - 19:47
  • Purple, 4500 points or more
pvdm2-32 should be enough to support 1 t1. plus a few channels left behind. the remaining channels if you want can be used for fxo/fxs ports.
pvdm can be shared across any type of vwic/vic
Sankar
PS: please remember to rate posts!~
