pix code 7.2 experiencing multiple icmp built and tear downs
May 16th, 2007
I am experiencing successive icmp built and teardowns with source and destination port(0) to the management interface. This might be a dumb question, but is this an attack? and I have ACL's on all interfaces to deny ICMP any ideas?
zulqurnain Wed, 05/16/2007 - 23:19
well, it looks like some sort of ping sweep?
HTH, please rate it.
srue Thu, 05/17/2007 - 09:30
ping sweeps on the Internet are a dime a dozen. However, if you're getting ping sweeps on your management interface, that sounds like an internal issue and should be addressed. Do you know where the icmp's are coming from?
(you do have your management interface on the inside of your network - and not at all reachable from the I'net?)
zulqurnain Thu, 05/17/2007 - 10:46
i agree with you, but he didn't mentioned about internet and he only mentioned about the management interface side of his firewall with icmp build and teardown.
if you can provide some more information it would be better to understand your problem
carlos.hernande... Thu, 05/17/2007 - 12:04
Thank you all for responding to this. It turns out that a logging statement on an internal firewall was firing to an old Syslog server and IP address.
The address of that old Syslog server was of a subnet on the inside. Since this system was not responding being it has been decommisioned, then the logging was being directed out the gateway to a perimeter firewall which in the PIX logs was the Source and the Inside interface of the Inside interface was the destination. Unfortunetly the PIX logs from ASDM were not descriptive, and it wasn't until an Ethereal capture that it was found out.
Lessons learned, keep logging statements up to date. Second, can't rely on the PIX ASDM logs for detail errors on the network. It did indicate there were problems.
