Force Authorization Code on Call Manager Express
May 16th, 2007
Would like to know how to implement Force Authorization Code on Call Manager Express? Basically, when users want to dial a IDD call, they are required to enter a PIN before they can make the IDD calls.
Paolo Bevilacqua Thu, 05/17/2007 - 02:27
  • Hall of Fame,
    Founding Member
In CME, FAC means Feature Access Code. The PIN blocking is described in the documentation under "after-hours service and login".
boonwah-tay Thu, 05/17/2007 - 02:59
According to the CME Administration Guide
"Individual phone users can be allowed to override call blocking associated with designated time periods by entering personal identification numbers (PINs) that have been assigned to their phones.
For IP phones that support soft keys, such as the Cisco Unified IP Phone 7940G and the Cisco Unified IP Phone 7960G, the call-blocking override feature allows individual phone users to override the call blocking that has been defined for designated time periods. The system administrator must first assign a personal identification number (PIN) to any phone that will be allowed to override call blocking.
Logging in to a phone with a PIN only allows the user to override call blocking that is associated with particular time periods. Blocking patterns that are in effect 7 days a week, 24 hours a day, and they
cannot be overridden by using a PIN"
1. To me the statement means that, that PIN authorization will not have effect on the command "after-hours block pattern 1 91900 7-24" and this pattern "91900" will be blocked all the time. This means I cannot use PIN authorization for the pattern "91900". Is my interpretation correct?
2. If my interpretation is correct, and I still want to have PIN authorization for the pattern "91900" all the time, then can I use the following command instead of using "after-hours block pattern 1 91900 7-24"?
telephony-service
after-hours day mon 00:00 23:59
after-hours day tue 00:00 23:59
after-hours day wed 00:00 23:59
after-hours day thu 00:00 23:59
after-hours day fri 00:00 23:59
after-hours day sat 00:00 23:59
after-hours day sun 00:00 23:59
Thanks!
Paolo Bevilacqua Thu, 05/17/2007 - 03:05
  • Hall of Fame,
    Founding Member
I didn't saw the paragraph about "full-time block cannot be override", and haven't tried that. I guess you will have to try it yourself!
