Reg: City Code
May 16th, 2007
Hi Guys,
We have a office in china and the code for the city is 021. ChinaNetcomm has annouced that if anyone wants to make a call in the city it should only have 8 numbers. Right now when the user in china office dials out say 61609999, the cisco ip phone will show on the screen the number dialed as 02161609999. Could anyone please tell me how to change it. I have gone the whole router setup but could not find any translation rules etc which is doing this. For exmaple the chine office has H323 gateway which will talk to our call manager in australia. Pls find below the configuration of the H323 router:
translation-rule 2
Rule 0 ^. 0
translation-rule 1
Rule 0 ^6160 41
translation-rule 3
Rule 0 ^41 6160
interface Serial0/3/0:15
description PSTN China Netcomm +86216160XXXX-XXXX
no ip address
isdn switch-type primary-net5
isdn incoming-voice voice
isdn send-alerting
isdn bchan-number-order ascending
isdn sending-complete
no cdp enable
voice-port 0/3/0:15
translate calling 2
translate called 1
echo-cancel coverage 48
cptone CN
dial-peer voice 101 pots
destination-pattern 0T
translate-outgoing calling 3
incoming called-number 0...
direct-inward-dial
port 0/3/0:15
Could someone please help me. Do I have to look in call manager. I dont think so because the local calls are forwarded to the PSTN. If I am wrong please let me know where should I find this in the call manager.
Tks
gogasca Thu, 05/17/2007 - 23:04
  • Green, 3000 points or more
You say that Cisco IP Phone only dials 61609999 to reach a local number right?
Dial-peer 101 its 0T as destination pattern.
So please run a debug h225 asn1 and debug voice ccapi to see how many digits CCM is forwarding to GW.
Check also the Route Pattern being used to see if its prefix any digits.
