vitripat Thu, 05/17/2007 - 01:27
  • Gold, 750 points or more
I would recommend an upgrade to the latest interim version in 7.2.2 chain. 7.2.2(20). No code is currently known is bug-free however it doesnt mean that a particular bug would hit your device also. Bugs are "triggered" if some condition is met on the firewall.
Hope that helps.
Vibhor.
alex.chung Thu, 05/17/2007 - 01:33
Thanks, Vibhor.
bty, Can I directly upgrade from 7.1(2) to 7.2.2(20) instead of upgrade step-by-step to 7.2(1) first, then to 7.2(2)?
vitripat Fri, 05/18/2007 - 05:37
Yes, you can directly upgrade to 7.2.2(20).
HTH.
Vibhor.
h.parsons Fri, 05/18/2007 - 10:22
Where would you find 7.2.2(20)? The latest I see is 7.2.2(19)
laurent.geyer Mon, 05/21/2007 - 07:51
If you're terminating site-to-site VPN tunnels on your 5510 then you want to know about CSCsi40796.
Bug causes TCP connections over existing VPN tunnel to be torn down randomly. Tunnel stays up but TCP get's terminated with following message logged:
Apr 04 2007 09:18:06: %PIX-6-302014: Teardown TCP connection 859314 for outside:192.168.90.103/1673 to inside:192.168.120.211/1025 duration 0:43:25 bytes 570 Tunnel has been torn down
No work around and no interim release that fixes the problem.
