IP IVR - GET DIGIT STRING - Initial Time Out
May 16th, 2007
I am having a minor problem with the scripting of the IVR. I am using GET DIGIT STRING to get the DTMF data entered. The clients claims that the Australian STD requires 10 secs for Initial Time out, but the script editor only allows me up to 8. Anyone can help me?
Overall Rating: 3 (1 ratings)
david.macias Thu, 05/17/2007 - 07:35
  • Blue, 1500 points or more
Why don't you have to nested Get Digit String steps, put the 2nd step inside the timeout step of the first. Maybe divide the timeout 5 and 5 seconds, the second GDS could have a silent prompt.
david
bmateev Thu, 05/17/2007 - 11:08
Use "Extended Get Digit String".
Set an Integer variable to 10 and select the variable in your initial timeout.
--Borislav
andrescoghlan Fri, 05/18/2007 - 03:57
I have tried the solution that you gave me, using "Extended Get Digit String" and using an integer variabe for initial timeout. But the CRS Editor validate it as OK, but executing the script it does not work, the IVR report an error. Debugging the script the message returned by IVR in Extended Get Digit String step is: "Out of bound; expecting maximum of 8".
Do you have another solution?
bmateev Fri, 05/18/2007 - 12:06
Here's what you do:
Record a prompt of 10s silence and place a "Play Prompt" step using the silent prompt and set the Interruptible to "Yes" right infront of your "Extended Get Digit String"
That will be your initial timeout.
--Borislav
