Fibre Standard in HongKong
May 16th, 2007
Hi Guys,
We need to install a cisco switch which has a GBIC Fibre module installed. Right now I am in Australia and here we will use LC to ST to connect to the patch panel. Does anybody know whether the same will work in HongKong. The only piece of infomration I got from them is they use the following :
6-core M/M50 /125 indoor Fibre cable
If I get a LC to ST cable will it work with the above in HongKong.
Tks
An appropriate fibre-optic cable with an LC connector must be plugged into an SFP on the PA-FC-1G. If the SAN switch to which the PA-FC-1G is being connected has an SFP module installed, an LC-to-LC fibre-optic cable is recommended. If the SAN switch has a GBIC module, use an LC-to-SC fibre-optic cable.
Kindly go through these links to get detailed information
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_installation_guide_chapter09186a008014aa17.html#1070605
