802.1x Authentication Configuration
May 17th, 2007
I have one 3560 L3 Switch and trying to configure 802.1x. All configuration seems fine but I think I'm missing something on the server side or Client.
Which configurations do i need to do on server side ? thanks for your help
luis.gomez-bast... Thu, 05/17/2007 - 07:19
Client side: windows XP / 2k (SP4)EAPOL client
Radius side: we?ve worked with MS IAS imported users profiles from MS Active directory also EAP and EAPTLS and it?s running fine.
Luis
albayrak8791 Thu, 05/17/2007 - 23:35
Can you provide bit more details about server configuration ? All i need is to know about the IAS part...
luis.gomez-bast... Fri, 05/18/2007 - 05:53
Next monday Iwill try to send you more info about Radius Server config.
Good week end
Luis
davidfc_A Fri, 05/18/2007 - 09:55
The microsoft document named "Securing Wireless LANS With PEAP and Passords" have a good explanation about IAS, architecture, placement, configs...
It is not the same authentication mode that you are asking, but it will help.
Best Regards!
