SIP 400 Bad Request
jamessohotha
I'm getting a bad request error when attempting to an outbound SIP call on a IP2IP gateway (H323 -> SIP).
It's a slightly odd configuration as we will only be using this route for outgoing calls only. The only error message I get is:
//-1/xxxxxxxxxxxx/SIP/Error/sipsdp_add_standard_lines: media_src_address is NULL; c-line is not added
SIP Invite message:
Sent:
INVITE sip:07970315632@192.168.1.2:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.1:5060;branch=z9hG4bK11222C
From: "anonymous" <sip:9000@192.168.1.1>;tag=404CF30-282
To: <sip:07970333333@192.168.1.2>
Date: Wed, 16 May 2007 13:09:44 GMT
Call-ID: 8CB2BA8E-2E511DC-8013CD38-94E8A35E@192.168.1.1
Supported: 100rel,timer
Min-SE: 1800
Cisco-Guid: 15103203-2971783453-520093696-2887190163
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Remote-Party-ID: <sip:9000@192.168.1.1>;party=calling;screen=yes;privacy=full
Timestamp: 1179320984
Contact: <sip:9000@192.168.1.1:5060>
Call-Info: <sip:192.168.1.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: telephone-event
May 16 13:09:44.608 UTC: //-1/xxxxxxxxxxxx/SIP/Info/HandleUdpSocketReads: Msg enqueued for SPI with IP addr: 192.168.1.2:5060
May 16 13:09:44.608 UTC: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x00000000
May 16 13:09:44.608 UTC: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:SIP/2.0 400 Bad Request
To: <sip:07970315632@192.168.1.2>
CSeq: 101 INVITE
User-Agent: 2N StarGate V-02.20.47
Allow: INVITE, BYE, ACK, CANCEL, OPTIONS
Content-Length: 0
Any ideas?
5 Replies 5
joncbanks
Have you found a solution to this? I'm getting the exact same SIP error message and we are also using a H323-to-SIP gateway.
However rather than getting a 400 error I am recieving a 480 error - Temporarily Unavailable.
I'm connecting to a Mitel PBX via a SIP trunk.
Afraid not, still working on it....
joncbanks
For what its worth, I had the same problem from Callmanager to an IOS IPIPGW. I was getting the SIP/2.0 400 Bad Request - 'Malformed/Missing Contact field' error message. Turns out I had mistyped my caller id mask and was sending characters in place of numbers. By correcting it, my problem went away.
Todd
jamessohotha
Made a mistake and the IOS version I am using doesn't actually support the IP2IPGW features.
Need to install more memory to get the 12.3T IOS it requires though...
