Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928938members
1242818discussions
Community Activity
NDFC: Switch を NDFC Fabric に追加しなおす手順
はじめにトポロジー手順1. 該当スイッチを Fabric に Add2. L3 に接続している S1、S2 側のポートを no shutdown3. Push Config/Recalculate and Deploy4. Recalculate and Deployまとめ参考資料   はじめに この記事では、NDFC (Nexus Dashboard Fabric Controller) の Fabric から削除されたスイッチを、再度 Fabric に追加しなおす場合の手順を紹介します。 な...
szong by Cisco Employee
  • 0 Views
  • 0 replies
Help with routing vlans
Can someone tell me how do I do routing here ? it does not matter if it is static or dynamic I just want to ping same vlans and also I dont want to have different vlans to be pinged
Interface Vlan administrativamente inativa
Acabei de criar uma vlan, atribuí-la a uma porta em nosso 6509, atribuí à vlan um endereço IP e quando eu disparo o comando, show int vlan 31 ele diz que a vlan está administrativamente inativa. Não consigo descobrir o que está acontecendo aqui? emit...
ftoprakw by Level 1
  • 74 Views
  • 1 replies
ACI: Dual Role Switch の Discovery について
はじめにDual Role Switch とはDiscovery の注意点参考文献 はじめに 本稿では Dual Role Switch の Discovery について、解説します。なお、この情報は 2024 年 04 月 23 日現在の情報に基づいています。   Dual Role Switch とは ACI Fabric を構成する Switch として利用できる機種の中には Leaf/Spine の両方になれる機種が存在します。そうした機種のことを Dual Role Switch と...
takasano by Cisco Employee
  • 20 Views
  • 0 replies
Resolved! BGP using Layer 3 Switches
Hi All,I have 2 networks connected via OSPF. I need to route the connected networks to a third network via BGP.I noticed that BGP peering is established but no entry is visible on the routing table.Below is an extract of BGP config:router bgp 65200.1...
Ranjita by Level 1
  • 213 Views
  • 11 replies
Access Point WAP150 Single Point
I have questions in cluster settings.   (1) Number of WAP devices per single point setting WAP150:4 Does the setting 'WAP150:4' indicate that a maximum of 4 WAP devices can be connected in a single cluster?   (2) Registering an AP in a Created Clu...
Translator by Community Manager
  • 9 Views
  • 0 replies
Trunk commands for ISR ESM?
Hello,At my home, I had an 8 port 2960G switch die after a power outage today.  I replaced it with a ISR 1921 that has an 8 port ESM.  It's been a very long time since I messed with configuring ESMs...  My plan was to just copy over all of the switch...
Service impact on ISE certificate renewal
Hello. I'm trying to renew the ISE's certificate, but I'm using both admin and eap authentication, portal, and radius DTLS. In this case, I would like to know if renewing this certificate will reboot the ISE or if it will cause downtime. The certific...
CCC3 by Level 1
  • 31 Views
  • 0 replies
Resolved! ISE integration with Prime Infrastructure,
Hi Team,   I would like to know what are the advantages and Disadvantages of the ISE integration with Prime Infrastructre.Also  how the LAN, wifi, and identity management part (guest access etc) will work together.  Cheers!!!Minakshi
minkumar by Level 1
  • 7041 Views
  • 8 replies
