Generating L4 Traffic
May 17th, 2007
Hi Guys,
Have just setup the S650 any ideas on how to generate malware traffic without installing malware internally?
DaltonHamilton_... Tue, 02/05/2008 - 17:06
I've written an OSX application that acts as a web-crawler. I point it at a single web-site and it takes off (with certain control paramaters). If you point it to a questionable starting point, within minutes your S-Series will start showing all sorts of malware and other L4TM stats.
Again the application runs on Mac OSX so if you have a Mac and want the app you can email me at [email protected].
Dalton Hamilton
IronPort Cisco
conorgeraghty_i... Fri, 04/24/2009 - 12:39
you mention that you have a site that can provide testing capabilities for IronPort. I do not have a MAC, do you know of another method whereby I can generate malware and other L4TM stats so that I can confirm my device is working.
jowolfer Mon, 04/27/2009 - 17:03
You should be able to just telnet to a forbidden site. Such as:
telnet 80
This will create a TCP socket with this malware server and the L4TM will pick it up and block / monitor it accordingly.
Since you are not using a browser, you are safe.
