Wireless bridges (Cisco 1310)
May 17th, 2007
I am looking to connect a remote location to our main LAN via a wireless bridge (Cisco 1310). I was going to use a WAP (Cisco 1100) at the facility end but someone told me that a bridge can only communicate with another bridge.
Is this true?
If this is the case, then I would have to use (2) Cisco 1310's correct?
thx
paolo bevilacqua Thu, 05/17/2007 - 07:35
  • Hall of Fame,
    Founding Member
Yes for true bridging you will need to use two bridges. You can send further queries to the wireless forum too.
james0816 Thu, 05/17/2007 - 08:40
What do you mean by "true" bridging?
The remote location will only be sending data to a machine on the LAN. There will not be any communication back to the remote segment.
