Remote config of router over Frame-Relay
May 17th, 2007
There used to be a way to configure and up stream router to supply an IP address to a new down stream router and then allow tftp of the config. Is this still supported? I cannot find a document on how to set this up.
cromo Thu, 05/17/2007 - 12:52
Sundar,
Thanks for your reply. While the specific web page did not provide the exact configuration I needed, it did point me in the right direction.
Chris
sundar.palaniappan Thu, 05/17/2007 - 13:41
  • Green, 3000 points or more
Chris,
I guess it's not a popular feature from the fact there isn't much documentation available on the web. I remember having done a lab on this a long time ago and indeed it works the way it's supposed to do :) Just play with it in a lab environemnt and let us know how you do.
Sundar
