05-17-2007 06:44 AM - edited 03-05-2019 04:08 PM
Please, look at this command line output from a 2811 router I am configuring:
borderman_ng.cesce#conf t
borderman_ng.cesce(config)#ip route 172.20.0.0 255.255.0.0 213.171.236.254
borderman_ng.cesce(config)#exit
borderman_ng.cesce#show ip route 172.20.0.0
% Network not in table
S 172.17.0.0/16 [1/0] via 131.15.254.1
S 172.19.0.0/16 [1/0] via 131.15.254.1
S 172.21.0.0/16 [1/0] via 131.15.254.1
S 172.29.0.0/16 [1/0] via 131.15.254.1
?????? Can anyone tell me why the new route is not added???
Thanks in advance.
Sergio.
Solved! Go to Solution.
05-17-2007 06:50 AM
IOS needs to be able to resolve the next hop for the static route to be installed in the routing table. Verify that a route to 213.171.236.254 exists in the routing table (preferrably directly connected).
Hope this helps,
05-17-2007 06:50 AM
Sergio
When you configure a static route the IOS will put that route into the table is it believes that the next hop is reachable and it will remove a route from the table if it believes that the next hop is not reachable. So I am guessing that 213.171.236.254 is not reachable.
Can you check the routing table and see if 213.171.236.254 is reachable?
Rick
05-17-2007 06:50 AM
Hope this helps,
05-18-2007 02:34 AM
Hi Sergio,
As posted by Rick, reachability should be there to the next hop i.e. 213.171.236.254 then only it will show in routing table. I will suggest you to kindly check the connectivity first.
Manish
