networking two sites together
May 17th, 2007
Please i have a router series of 1700's. i have fixed the voice card.Please can you put me through with the configuration to connect the two site together,pleease help.All your is highly appreciated
spremkumar Fri, 05/18/2007 - 03:39
  • Red, 2250 points or more
Hi Will
Can you post out the output of the show version command taken out from both the routers ..
That will help us to understand the exact card model installed in the router and will be easy to suggest on configuring the same..
regds
willsdre01 Fri, 05/18/2007 - 05:04
Hi Kumar,
Thanks for your responds.i will send the show version on monday,cos i'm not in the access now
