Config copy
Answered Question
May 17th, 2007
Hi All
I want to be able to copy the config of each of our devices out to a back up server.
Please where is the directory that all the configs of the switches, routers etc are kept it?
Correct Answer by Joe Clarke about 9 years 8 months ago
Previous posts you have made tell you have CiscoWorks, so you can get the latest config from each device under /var/adm/CSCOpx/files/rme/dcma/shadow (Solaris) or NMSROOT\files\rme\dcma\shadow (Windows). Periodically backing up this entire directory structure will ensure you always have the latest configs from your devices on the backup server.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Thu, 05/17/2007 - 09:01
londint Thu, 05/17/2007 - 10:21
Thank you so very much. I forgot to put Ciscoworks in the question. lol.
Anonymous (not verified) Thu, 05/17/2007 - 09:31
Dear Londint,
Como Vai?
Eu Estu Tentando Portuguese!!!!
Are you satisfied with your Ciscoworks platform for configuration management?
Please let me know,
rich
