Exporting IP hpnes from one cluster to another
May 17th, 2007
I am currently working on a pkroject to migrate some users to another cluster in my network. I have some questions and wanted to see what would be the best way
1. Run the bat tool to export the phones on cluster 1
2.0 run then import bat tool to import the phones
3.- assoiciate the gateways to the new cluster
Question can i create in advance the device pool, location,mrgl etc for thatphones i am exporting?
The will be name the same can there be a possibly conflict since they will be named the same?
Mark Turpin Tue, 05/22/2007 - 10:16
Is there an ICT between these two clusters? You can create the standard things like device pools, locations, etc. ahead of time without an impact.
